steadyhand
- May 5, 2010
- Missouri
- 99 Mercury Mountaineer
I know very little about transmissions so keep this in mind.
I have a 99 Mountaineer, 5.0, 2WD auto. I have been chasing a thump sound that occurs when I come to a complete stop too fast and when I take off. I have replaced so many parts already. I used some Teflon (XG?) grease from the Ford dealership to put in the slip yoke. I am not sure if I put enough in the yoke, but what I did use didn't seem to make any difference.
While I had the drive shaft off I noticed the transmission output shaft moved when I pulled out the yoke. By that I mean it can literally be wiggled side to side quite a bit. I can't move it enough to touch it to the tail shaft housing, but it seems like a whole lot to me. I have rebuilt an 8.8 rear end before so I have a basic idea what tolerance something is simply by how much it gives.
Is the tailshaft suppose to move and if so how much? The movement would be determined in thousandths of an inch, right? If so there is something obviously wrong here. My output shaft moves like it is attached to a knuckle inside the transmission.
