stx4.0
- January 17, 2009
- ohio
- 94 sport
Ok I need a little help with this one or lots depending.I came across two early 4.0 powered vehicles cheap.One is a 93 explorer sport and the other is a 94 ranger 2wd with the 4.0.I got them from a guy that said he overheated both of them and wasn't willing to spend the money repair them.Since I can do the work myself I bought both.The explorer had a bad water pump failure and I tore into it and took the heads to a machine shop.The guy there told me the heads were not warped but the right side had a bad crack so I bought a set of alabama heads.The block I checked myself with a straight edge in the vehicle and it looked fine.The guy at the machine shop told me the heads would warp way before the block.I put the new heads on along with a new thermostat anitfreeze etc and it still overheats and I mean in a bad way like there is no coolant at all in it.The radiator was cleaned out and I was told it wasn't dirty at all and the clutch fan seems to be fine as well although it is not new.I am stumped on why this thing is overheating so bad.I thought the gauge might be bad but checked it with a thermometer and it definitely is getting hot..I am thinking the only thing it could be is the block.Is there anything I might have missed?The thermostat was installed correctly so no issues with it being backwards.I do not want to tear into the ranger and have the same thing happen.
