P0128 engine code | Ford Explorer Forums
P0128 engine code
gnelson13
Milwauke, WI
2004 Explorer 4WD
Does anyone know what service engine code 'P0128' means? The code reader says thermostat or coolant below threshold. My coolant level is good and I don't think I have a thermostat problem because my temperature gage holds steady. I have cleared the code, but get it back in a few days. Any ideas?
We have a great Computer section (especially the EEC-V -- which is what your truck is). I went ahead and moved it there. Its under the Underhood and Driveline section
Anyhow, visit here: http://www.explorerforum.com/forums/showthread.php?t=147880
That should help you find the code and should hopefully point you in the right direction. :thumbsup:
-Drew
I found this:
P0128 - Coolant Thermostat (coolant Temp Below Thermostat Regulating Temperature)
-Drew
Dtc P0128
Thanks, Drew. I've Googled the code and found it listed lots of places, but not one of them suggests what I do about it. Thermostats are cheap enough that I can replace it to see if that fixes it, but I don't think that's the problem. The vehicle never overheats and the temperature gage stays right in the operating range. Do you know if there is a temperature sensor somewhere in the system that might be faulty and triggering the DTC? I checked the link you provided, but didn't see anything about the P0128 code.
