P0174 after replacing Intake Manifold Gaskets- was P1151 and P0174 | Ford Explorer Forums
doug1105
Pittsburgh, PA
2002 XLT
So my wife's 2002 4.0 Explorer was stumbling when braking at red lights.
The Engine Light came on and spit up P1151 and P0174.
I did a search on here and talked to my mechanic, and he said "intake manifold gaskets", so I got a set and replaced them about 2 weeks ago. I cleaned up the intake and cleaned the mating surfaces, and torqued everything according to spec.
This week the engine light came on again and gave P0174. I took another look at the vacuum lines and nothing seems bad.
What do you guys think? It runs alright but it still has a slight stumble.
Check the fuel pressure, you must have 55-62psi at idle and all throttle settings. If it doesn't, the fuel pump, or regulator, or rubber lines between them is bad. Good luck,
I was out of town on vacation for a week. Thanks for replying to my post.
I'll check the fuel pressure, plugs and take a look at everything again.
I'll post any solution If I find it.
-Doug
Found that the clamp on the rubber intake bellows behind the MAF was loose and pulling air.
I must have forgotten to tighten it back up after doing the intake manifold gaskets. (what a dope)
Hopefully this takes care of it.
I will repost again if it does.
