P0175 Code.... HELP!!! | Ford Explorer Forums
ad9sloaccrd
Cleveland, OH
'05 XLT
Hello all;
I've been 'snooping' around these forums for quite some time, also did some searching with regard to this code number and can't seem to really get anywhere.
I have an '05 Explorer XLT 2WD Flex with 89,x... No matter what my mechanic and I do, we can't get rid of this code (running rich, bank 2)!
We've done:
-fuel pump replacement
-fuel filter replacement
-O2 sensor replaced (Bank 2, after the CAT - this sensor was a bit lazy while we ran diagnostics)
-Air filter
-MAF seems to be okay, but we haven't really taken a hard look at it
-pulled all spark plugs on bank 2 side to look for black plugs (signs of running rich) and they are all fine
If anyone else has run into this code and was able to solve the problem, please let me know what you did!! Anyone have any ideas?
Any input is much appreciated.
Hi,
Have you checked for a vacuum leak?
Might want to also check the DPFE since it is a cheap, simple part to replace. My father's mechanic had a problem chasing it down on his 2001 explorer. I got it right away, reset the computer and passed inspection fine.
--Phil
check for leaks along intake tube and where it meets the airbox, also where it meets the throttle body..i had this code awhile back and it was because the aftermarket filter I jimmy rigged on there was not air tight and slipped off, i replaced correctly and reset computer and code went away. I would assume it is along where the intake runs.
Thanks for the input guys - we're going to dig into this a little more when I get out of work today.
I'll update
Ford has tsb for update pcm for this code.
Printable View (6 KB)
TSB
04-22-11 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTC'S) P0172, P0175, P0171 AND/OR P0174 - 4.0L SOHC ENGINE - VEHICLES BUILT PRIOR TO 10/4/2004
Publication Date: October 28, 2004
FORD: 2004-2005 Explorer
MERCURY: 2004-2005 Mountaineer
This article supersedes TSB 04-19-7 to update the vehicle model years and DTC information.
ISSUE:
Some 2004-2005 Explorer 4dr/Mountaineer vehicles built prior to 10/4/2004 with the 4.0L SOHC engine, may exhibit the MIL illuminated with one or more of the following DTC's:
P0172 - SYSTEM TOO RICH (BANK 1)
P0175 - SYSTEM TOO RICH (BANK 2)
P0171 - SYSTEM TOO LEAN (BANK 1)
P0174 - SYSTEM TOO LEAN (BANK 2)
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B33.10 or higher. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
042211A Check For Diagnostic Trouble Codes And Reprogram Powertain Control Module 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2004 Ford Motor Company
swetrid - where do I go to actually obtain the latest calibration release? Can't really find anything through Motorcraft. Haven't called my mechanic to ask him yet - his computer that he plugs into my car is a Snap-On MODIS - do you think this would be able to reprogram the PCM?
We checked for vacuum leaks - found nothing. Cleaned the MAF, but doubt this will do much. We hooked up the computer after we did this stuff and my long term fuel trim in bank 2 is a little over 25% (should be between -20% to 20%). I'm almost positive my light will flip back on tomorrow morning.
Dealer only for recalibration unless side shop has very specific special software. I would try reprogram first before any other repairs.
Okay - I'll contact my local dealer - any idea on what the cost would be to reprogram??
WE charge like 1/2 hour, so like about $50 depending on shop labor rate.
