P0442 code | Ford Explorer Forums
P0442 code
Jeeps&Fords
San Diego, CA
'97 XLT 5.0 AWD
Just wanted to share my experience with fixing this code. The code description is a minor leak in the evap system. Well, I went back through old postings and most problems seemed to be with the purge valve. So, I removed my valve, disassembled it and blew it out with air. I then verified that the solenoid was functioning. Put it back together and the code came back a day later.
Reading through the manual, I saw that a faulty gas cap can cause this error. I pulled my cap and found that the gasket was twisted, or rolled would be a better description. I carefully straightened it out with a screwdriver and popped it back into place. Viola! No more code.
Thanks for sharing!
