Henders
- July 10, 2007
- Buffalo, NY
- 2006 Explorer Limited
I replaced my solenoid with a Doorman about 6 months ago and haven't had any problems. You can always check the solenoid out before you install it by connecting 12V to the contacts and blowing through the unit. You should be able to blow air without power applied and not be able to blow air with the power applied. If air is able to pass when the valve is closed, then it's leaking and will fail. (Then again, the Doorman Issue might be just an issue with the Capless systems?)
