mranderson214
- August 3, 2010
- Brooklyn, NY
- 2002 XLT
Hey Everyone,
I have a problem with my explorer that maybe someone on here can help out with. I have a 2002 XLT, V6 engine, roughly 180K miles on it. The car runs great but recently something strange happened.
So the other night I went to park on a hill and put the shifter in Park. I had noticed that the car moved back a little bit (due to the hill). So i pushed the parking brake down in attempts to protect the transmission from the strain of being parked on a hill the whole night. I ended up having to push the parking brake pedal so a bit further than normal. Upon doing so, i heard the what sounded like a popping sound.
Now what happens is that the parking brake pedal seems to move freely throughout its mechanism. When pulling the release lever, the brake doesn't spring all the way up; I have to use my hand to lift it up completely so that the red "Brake (!)" light goes off from the dashboard. Pulling the release lever alone doesn't seem to spring the pedal fully back up but almost all the way up, though not enough to disable the "Brake" light.
When pushing the pedal down in attempt to engage the parking brake, the pedal moves freely down as if there were no tension within the cables.
I managed to get a look at the cable and brake pedal assembly from the INSIDE of the car but I haven't jacked it up yet. I plan to look under the car tomorrow. From the inside, I see the metal tension cable that the pedal should control. The pedal still appears to be attached to the cable as when I move the pedal, the cable moves. There is a lot of play in the cable's movement though. I am able to move the cable a bit with pliers (or fingers) from inside the car. The rest of the assembly appears fine, just the way I've known it to always look.
One thing that I should mention is that for the past few months, I realized that the parking brake pedal needed to be pushed further and further down each time in order to hold the vehicle when parked on a hill. I had previously read about parking brake adjustments but never done one. The night I heard that popping sound, I had to push the pedal down to nearly the floor and well, here I am now.
I don't think that its the brake pads for the parking brake as the parking brake had worked fine at holding the vehicle in place before. Not to mention that I had my brakes changed about a year ago and the mechanic (who I trust) said that the parking brakes looked good.
So, my question is, before I jack up the car tomorrow, what are some things that I can look for? I read up on some adjustment procedures but I'm not sure if that's what my problem is. I've already narrowed the problem down to something under-the-body, as everything in the passenger compartment appears intact but the metal brake cable. It seems as though the cable lost its tension somehow. Does it sound like I might need an adjustment?
Thanks in advance!
Thanks in advance!
