tafay1
- December 7, 2006
- Republic, WA
- 2005 XLT
Hi all. . .
I have a 2005 Explorer
, unfortunately, the parking brakes don't work properly; in essence, when the parking brake pedal is engaged it pushes all the way to the floorboard, and, of course the there is no braking. . .hence, the transmission is bearing all the weight of the vehicle
I thought that the parking brake could be easily "adjusted" with a nut/bolt so I traced the parking brake cable from the pedal to the real axle (left side) and I couldn't find a hint of an "adjustment" nut/bolt anywhere along the cable. . .Am I missing something, or, does the parking brake assembly at the hub have to be removed to make "adjustments"???
I would appreciate any assistance in this matter 'cause I don't want to have to repair the transmission.
Thanks.
Blessings,
Tim
Thanks.
Blessings,
Tim
