Parking Brake Issue | Ford Explorer Forums
Parking Brake Issue
colindo94
Cameron Park, CA
94' XLT
Well my parking brake hasn't rally worked to well for some time now. I made it so it could be manualy adjusted with an f-150 adjuster when I did the sas, but I can't get it adjusted correctly. It will drag all the time because its too tight or it won't engage because its too loose. I noticed that when I push the pedal to the floor the parking brake line barrly moves. I compared it to my bros and his pulls much more then mine. So I have kinda norrowed it down to the parking brake pedal assembly. I did a little research and found that there was a recall on this pedal from ford, but I don't know if that has anything to do with my problem. Any help or nolage would be great. Thanks
have you checked out the cable? they have adjsuters on them for tightness, have you examined the protocol for proper freeplay and are you within tolerance?
I have checked all the cables from the pedal to the drums. This is why think it has something to do with the pedal assembly.
