Parking Brake question..... | Ford Explorer Forums - Serious Explorations
1tufgt
Bluegrass St.
2003 XLT Sport Trim
What does a 2003 Explorer use for the parking brake? Brake Pads or Brake Shoes?
I know it is a disc setup but wasn't sure if there was shoes used as the parking brake.
shoes in the hat section of the rear rotors
How often do they need to be adjusted because when I press down on our parking brake it doesn't seem to hold like it used to.
Could it be that the rotor is worn so much that it could be the culprit?
Well, the rotor wearing will not effect the parking brakes. I would remove both the rotors and inspect. It is common for the parking brake shoes to come apart, rendering them useless. If everything looks ok then you can set and release the parking brakes and see if they move. Also check the parking brake surface in the rotor. it can get really rusty. too much rust and it is difficult to get the rotors off.
Yeah I need to change my pads and rotors so it sounds like I might need to load up on a heavy duty rubber mallet.
you can use that method, but there is a quarter sized knockout after which you can get to the star adjuster. i'd back them down and then use a hammer. Might be easier in the long run. I tried the BFH took a bunch of wacks when it did come off it took the shoe with it. .
