MrPulldown
- March 1, 2017
- Truckeee
- 2004, 4wd, 4.6l
What a tricky little *******. So many little parts to deal with. Did the driver side and calling it a win.
Was getting the rear end clicking noise. Did a search and read about the shoe's friction material separating from the metal. Typically I would take everything apart to confirm the issue then buy parts. However I felt lucky this time and just ordered a set of pads and a new hardware kit. Didn't look up an installation write up, just went for it. Took a minute of head scratching to figure out how the caliper comes off. Weird that half of the rear brake parts are part of the knuckle. I had installed new rotors and pads a little while ago but still took a while to recall.
The retaining pin and clip are the hardest part to deal with. Is there a way to easily remove the wheel stud flange? Any tips on doing this job. I need to get in and do the passenger side, though it is still working and the shoe has not separated yet.
