MythX
- January 3, 2012
- Colorado Springs, CO
- '04 Explorer EB
This happened a couple times last winter, but each times resolved itself quickly.
Anyway, my truck sat for 4 days this weekend, while I was home lazy. When I was headed out for work this morning though, my parking brake wouldn't disengage. The peddle popped out as expected, but put the truck in reverse or 1st and it just won't go anywhere. I suspect (though can't confirm) that it's just the drivers side based on the way it was trying to move. Anyway, after fiddling with forward/reverse and putting some, but not a lot of pressure on the gas, it finally came free as if it never happened.
Brakes otherwise give no issues, I made it to work, no problem, parking brake disengaged at lunch w/out incident. I suspect it's temp related, it's only ever happened in the mornings, and never when hot. This morning was a bit cooler/wetter than it has been.
Anyway, I wanted to tackle it when I get home from work, so I'm hoping for some ideas on what to check. I figure it's something that just needs to be lubed.
Truck is a '94 sport 4x4 with 5-speed. Pretty much all stock.
Thanks
Thanks
