Part # for Rancho RS9000X 92 w/4inch lift | Ford Explorer Forums
pmill
San Diego, CA
'92 XLT 4x4
It's got to be easier than this, but I have been trying to find a set of RS9000's that will fit my 92 w/4 inch suspension lift.
Has anyone bought these for their Explorers and know the part numbers of what I need?
I have the Rough Country lift if that makes a difference. Thanks to anyone that can help me.
Thanks. I actually just found the answer. Our explorers are only listed up to a 2 inch lift using the stock rancho shocks per their website, but here's a good answer I got from another member.
The answer is:
RS99115 - Front: listed on gorancho.com for 4x4 Toyota 4-Runner.
RS99266 - Rear: listed for Excursion with no lift.
Here's a conversation with good info talking about the differences in the RS99115 (Toyota 4 Runner) and RS99117 (Ford Bronco). Both fit, just different lengths.
DeRocha said:
Hi Paul..
The numbers in my profile are correct (Using stock mounting locations).. The only difference between (99115 and 99117) is their collapsed and extending lengths (the 115s being slightly longer); Both shocks have identical upper & lower mounting types. Check out http://www.gorancho.com/products/ap...cifications.pdf for the complete listing of their shock guide.. The nice thing about the adjustible shocks is that they can fit a wide variety of vehicles because they don't have a static dampning rate.. Obviously the static rate of the excursion shock would be way to much for the explorer, but that rate would be about a 5 on the rancho setting. All you do is dial it down to where you like the ride and you're good to go (I run it at 2 on road and 5+off road)..
(shock,upper mount, lower mount, collapsed, extended, travel)
RS99115 S42 L1 13.250 20.625 c 7.375
RS99117 S42 L1 12.250 18.625 c 6.375
