Part Number for Middle U-Joint | Ford Explorer Forums
BigDave
River Forest, IL
'94 XLT 4x4
Anyone have the part number for the inner (middle) u-joint on the pass. side drive shaft? I think that mine is toast and want to replace it, just need to make sure that I get the right one. Hoping to do this without taking out the drive shaft too as I need to get in the pumpkin to do that.
So, if anyone has that part number I would really appreciate it. It was not at FordPartsNetwork.com.
Dave
There are 2 diff sizes 1.188" and 1.063" (outer diameter of the bearing cap). My '93 uses the larger 1.188" U-joints... As for part # it depends on what brand you buy.. You will have a few choices such as greaseable, heavy duty, and standard duty. If you want info on replacing U-joints check out the links in my sig. I had the luxury of working on the U-joints on my Bench as I removed the TTB from the Explorer.
All 3 U-joints on the front axle are the same...
