Parting out 94 Eddie Bauer | Ford Explorer Forums - Serious Explorations
My truck is now officially dead. Tried to fix the tranny problem with a new TC, didn't work. So now it's time to call it a goner and part it out.
The truck doesn't engage in gear, and the transmission makes a nasty whirring/grinding noise. Thought it was the Torque Converter, replaced it, it wasn't the problem.
The truck has around 240k on it, and is fairly solid otherwise. Has normal rocker and wheel well rust, but the undercarriage is solid.
Truck is now being sold as one piece only. If you are interested please send a PM. It is not drivable but can definitely be towed. Would prefer to have it picked up, but I can haul it very short distances as well if needed.
How much for the windshield, power steering pump, pump pulley, power steering gear?
Shipping to 80526
How much for the running boards and all brackets and bolts?
$20 plus whatever shipping ends up being, but I'll warn you, the running boards show their age, and the brackets are going to be pretty rusted up. For that reason too I'm not sure I would be able to save all the bolts. I can get some better pictures of everything if you want me to.
How much for the rear drive shaft?
Did the rear hatch wiper motor work on it? If so and you would like to pull it, how much?
I'll take $30 plus shipping for the drive shaft, it has greasable u-joints with around 15-20k on them.
Yes it works. $15 plus shipping for it.
How much for the shift motor shipped to 22802, if ya wanna separate it?
What do you need for the front coil springs shipped to 58503?
Mass Air flow sensor to 01056?
As stated in the first post, I can't remove anything that prevents the vehicle from being rollable. Granted it might be without springs, but I'm not really sure. Unless you have an idea on how to keep it movable without, I can't sell them to you.
Do you want just the sensor or the housing as well? I'll give it to you with the housing for $35 shipped.
Just need the sensor. Yards here want $40, was hoping for less
