DidiDavis
- July 18, 2010
- Davis, CA
- 1996 Explorer Eddie Bauer
I just bought a 1996 Explorer Eddie Bauer V6 4x4. Today I realized that the right headlight low beam (passenger side) and the fog lights are not working. The left headlight works fine, and the high beam works on both left and right headlights. If I push the fog lights button nothings happens, not even the button lights up.
I read through the forum and the manual and found useful information. The right headlight and fog share the same fuse, but that fuse and all the other fuses on the dash (driver's side) are good. However, the shared fuse has only one wire connected to it, is that the way it is supposed to be?
I replaced the fog lamp relay (6 bucks at Napa), but still, he lights are not working. I am hoping this is a common problem of explorer with an easy (and cheap) fix. Do you guys have an idea of what the problem could be?
Thank you!
Thank you!
