ronstott
- May 7, 2009
- Ann Arbor, Michigan
- '06 EB '02 XLT '92 XLT
Maintenance schedule indicates that PVC flow should be checked on the 3V engine. I ordered a Motorcraft replacement PVC valve to be on the safe side. Examining the engine I haven't located anything that looks like this part. They are usually easy to located. On Generation 3 V8 they are located on the valve cover, a pretty normal position for a PCV valve. To double check that this is a valid part I checked a number of parts sites. There are a number of part houses that associate this part (EV-269) with this engine. A number of parts houses don't stock a PCV value for this engine. For example FordParts.com didn't.
Does anyone know where I can locate an exploded diagram for this engine without having to buy a service manual CD or an expensive subscription service.
It is also possible that the PVC value is built into the intake manifold which would create a bit of confusion, since this would be atypical.
Has anyone that has this engine (2006 to 2010) in the Explorer configuration has had the PVC flow checked or have replaced a PVC valve?
Cheers!
Cheers!
