pitman arm removel | Ford Explorer Forums
pitman arm removel
stil
91 explorer
does anyone know how to remove the pitman arm to replace the lower seal on the steering box
You need a pitman arm puller... Something like this: http://www.amazon.com/OEM-25262-Pit...=1411231906&sr=1-2&keywords=pitman+arm+puller
Welcome to the forum:chug:
Thank you I got it off but ended up taking the gear box out , but now I can't get the seal out I tried drilling a small hole in the old seal but had no luck without damaging anything, is the only way too get that seal out by taking the whole shaft out ?
pitman arm seal
Sorry, I've never removed the seal, just the pitman arm itself. Maybe someone else has an answer for you.
pitman
thank you but i got it and already reinstalled it ,, thanks again
