It would seem unlikely that both high beams would fail at the same time. I believe the low beams are LED and the high beams are actual bulbs (9005LL). I don't see any fuses listed for the headlamps so I wonder if they are controlled by the BCM?Is there a known fix to get high beams back? 2017 PIU. When I pull the lever back I get nothing. How can I get my high beams functional?
Not according to the manual. Page 198 shows you how to change a headlamp bulb. Should be a simple twist and turn.I think I have to remove the entire assembly to check the bulbs?..............................................
The 2017 Interceptor like the 2017 retail unit has an LED low beam and a regular 9005LL bulb for the high beam as I mentioned in post #6.My '17 has projectors. I read somewhere that they just raise the louvers on the lenses to get high beams. Not sure the truth to that, but might be something to look into.
Good thing you didn't. Those LED's will blind you!I thought they were projectors. I didn't look at them too hard though.
They may be emergency lights ... Or just the housing.I'm going to dig into when it isn't 20 degrees outside but honestly have no clue if they even have bulbs or wiring hooked up.
And I see you got yours in Chicago. Hello, neighbor.
If nothing else, getting the emergency lights model and putting in some strady-burn white in there would work well.They are just the housing. There are no bulbs installed. I'm going to look into if I can add them. I'm guessing someone swapped it in. I like the look, but having them work would be nicer.
