4x4man
- August 17, 2008
- Norway
- '96 XLT
Last night I noticed the light starting to blink on and off, and now I got some weird problems with the lights.
The low beam only function with the headlight switch set to OFF, but then there is no lights in the instrument panel.
When I set headlight switch to ON no lights in front, but instrument panel lights up.
High beams only work when flash (when the lever is pulled toward the steering wheel).
All fuses are ok, but is there a relay making causing this problem or maybe the headlight switch?
Appreciate help how to sort this out?
Cheers
Frank
Cheers
Frank
