zaneinsain
- April 24, 2017
- Mesa az
- 93 explorer 4x4 xlt
Hello I'm very new to the Explorer forum I was wondering if anyone out there has had the same issues me or might be able to help and I'd like to pre apologize for anything misspelled or bad punctuation I've got a 93 Ford Explorer with a 4.0 4x4 v6 reason I put it on the non-stock Explorer form is because it's set up for off-roading lifted on 35s moved or changed please feel free to do so but the issue I've been having was at first I had a random misfire one week ran like a raped ape next week it would died every single stoplight I've had to stop at. now it's constant misfire and wants to still died every stoplight I have replaced both O2 sensors mass air flow sensor throttle position sensor fuel pressure regulator crankshaft position sensor spark plugs and fuel filter replaced fuel pump about two or maybe 3 years ago at the same time I did the head gasket I have check fuel pressure I believe I'm running around 30 to 35 PSI and I have pressure tested on my cylinders there around I think 150 it's been a while any advice would be much appreciated thank you
