Mikebluestar
- January 21, 2022
- Nooksack
- 2010 Ford explorer 4.0
Need help with my wife's explorer I replaced the servos and the solenoid pack and now I'm getting a p0713 TFT sensor circuit high voltage input , if p0733 transmission gear number 3 incorrect ratio and a p0745 EPC circuit fault and then when I clear the codes it sometimes says pressure solenoid a I did have to buy an aftermarket plug that plugs into the transmission because mine was cracked and brittle but I did one wire at a time and heat shrinked everything can anybody help me out here
