Tazkb
- June 22, 2011
- Bolton Lancashire UK
Ok so my 97 4.0L Explorer is stuck in 4 wheels high, my mate came round yesterday to have a go at fixing it or if not being able to fix it to leave it in 2 wheel drive so I can at least use it, as i'm disabled and need the truck.
he got as far as removing the 4x4 motor to find the plate behind it, a quick look on here showed a picture of the plate but mine is different, mine has on it
4 hi, 4 low and neutral ? anyway with the back end jacked up we operated the motor which worked fine on the interior switch, which says Auto, 4 high and 4 low, he couldn't see any other motor i.e. one for the transfer box. so I need the following help please.
1: a picture of the transfer box or better still and exploded diagram
2: any information of how to disengage the 4 wheel drive, leaving the truck in 2 wheel drive, without removing the prop shaft. ? please
it seems like the 4x4 is stuck in without the truck knowing it ? because the 4x4 light only comes on inside the truck when I physically switch it to 4x4 high, when it's in Auto the light stays out ? and when I switch it it just comes on, no flashing just comes on. everything else works ok (well except the blend door on the heater) I believe there is a solanoid that activates the 4x4 high but where is it located ?
if someone can please help me and my mate solve this problem I will be eternally greatfull as it's driving us mad and without the truck it's making life difficult.
thank you
Keith
thank you
Keith
