Please Help | Ford Explorer Forums
Please Help
MrBean972
Dallas, Texas U.S.A
1994 Explorer Limited 4x4
Ok guys here is what is going on.
Today i installed a new light switch because my instrument panel dimmer quit working.
Well after that i went for a drive and noticed that my voltage gauge was half its notmal reading and i noticed it started getting lower and lower.
Well i went to autozone and had them test the alternator and it tested bad. Well i bought one and put it on right there in the parking lot while they charged my battery. Then i started the car and noticed my voltage meter was inb the same spot. I went back in and got the guy and told him what was going on and her tested the new alternator. Well it appeared to be bad also. Well in return we went inside and got my old Alternator and put it on the bench tester and it tested perfect.
Then we came outside and come to the conclusion that the plug that goes into the voltage regulator isnt sending a 12volt lead to the alternator to tell it to turn on.. When we wire a direct witre from the battery to the Green and red wire on the alt it starts charging and my volt meter rises.
Have any idea what this could be ??
Also i checked both fuse boxes.
Please help.
Thanks in Advance,
Nick
