Mike65
- December 31, 2013
- Horsepasture, Virginia.
- 2005 2WD Regular Cab F150
Now that I finally got the Evap codes fixed a few weeks later the CEL comes on & I am like oh **** not again, but it was po171 & po174 codes banks 1 & 2 lean. When my wife starts the truck it starts fine & for a couple seconds will idle fine, then the idle drops off like it is going to stall then it comes back to normal idle & is ok. It drives fine with no hesitation, or stalling. Today I found on line that it could be a dirty MAF sensor so I pulled the MAF sensor & sprayed it with MAF cleaner & reinstalled it, It also said check for vacuum leaks so I sprayed the cleaner around the IAC, egr valve, & where the egr tube goes into the upper intake with no change, but tracing vacuum leaks on the 4.0 SOHC motor are hard to get at a lot of the vacuum lines that are under the upper intake. It also said low fuel delivery could also cause the codes as well as a bad DPFE sensor. The Explorer Sport has the 4.0 SOHC engine with about 110,000 miles on it. It also has a new fuel pump which I replaced last year for a no start cold problem, but the fuel filter is old. Where is the port to check the fuel pressure on the 4.0 SOHC engine?.
