snowplow
- January 6, 2016
- 99 Explorer 5.0
Hey guys, I got a PO305 code and I can see in the live data that it is only misfiring pretty much at idle. I can tell it idles a bit rough. I have put new plugs everywhere and replaced #5 and #8 coilpacks just now. Still got PO305.
Swapped new #5 coilpack with old #7 and scanned. Still got PO305 so the new coilpack must be good. Cleaned the MAF out of desperation, tested #5,6,7,8 coilpack harness plugs with my power probe. Not sure what they should test like but I compared them all to see if #5 was different. All the same with 0v on one side and steady 14v on the other. Looked with engine running in dark and saw no arcing at plug or anywhere. Scanner says no fault on any injector.
I'm totally stumped now. Any ideas??? This is my first time using a scanner BTW.
THANK YOU FOR THE HELP!
