David S.
- February 25, 1999
- Utah
- 2020 Altima AWD
I am having a couple of problems with my drivers side front wheel. Sometimes when I press the brake, i hear a popping sound. Let go of the pedal and push again, it does the same thing. There is also a rattle from that same wheel when I go over bumps.
As you know when you remove the wheel, part of the hub comes off as well. If I shake that part of the hub, I can hear a rattle in the hub, although it does not sound the same as the previous sound I mentioned. Does this mean my auto hubs are going bad?
