Yup,....or a ball joint, or a sway bar bushing, or a sway bar link, or something else loose under there. There are several usual suspects in that area. I wouldn't buy or replace anything till you get it narrowed down. Try shaking the steering wheel side to side. This will usually reveal a loose tie rod end. If nothing then raise the corner and check for balljoint play using a prybar.
