JohnnyFiveOh
- July 10, 2002
- Ontario, Canada
- '91 XLT
I've swapped engines in my old Capri a couple times, 3.8 to 5.0 to 351W. Both were with no donor car and searching for odd parts everywhere.
What I've learned is that you need to research what parts from existing vehicles will work.
I'd still like to put a 5.0 in my truck in a year or two, but will make sure between now and then that I collect ALL the parts needed to finish the swap.
What I've found is that I'll need an intake that can clear the heater box (one with sharp bend like '94-'95 mustang or '91 Thunderbird).
Wiring is just a matter of researching schematics of manuals (Haynes).
AOD Tranny adapter from AA - Expensive but the only non Ford part necessary.
Exhaust - This is the biggie! Can you use any Ford exhaust products to COMPLETE the entire exhaust without any custom fabrication?
I wonder why people haven't previously mentioned the possibility of using the same parts off a '96 up EX with V8?
Why not buy used shorty headers, and either good used Y pipe and Cats or even buy whole new system?
The body and mounting points are the same right?
As far as the extra O2 Sensors it uses, just pipe plug the holes and use the other two.
I still have motor mounts from my '88 mustang and other odds and ends.
Does this sound reasonable?
