RaveDigger
- April 2, 2010
- Groton, MA
- 2000 Sport 5 speed manual
So I spent the past two nights after work removing the interior panels in my 2000 Sport (no easy task) and installing a set of 6x9's that I had lying around. 6x9's don't really fit, but I convinced them to fit with a sawzall and a dremel.
So basically the setup that I have is:
The existing rear speaker wires are running directly to my aftermarket amp from the stock headunit as speaker level inputs.
The amp is connected to the two 6X9's.
The remote amp power on wire runs from the 12v yellow lead at the back of the stock headunit to the amp.
The positive 8 gauge wire comes from the positive terminal of the battery all the way back to the positive connection on my amp.
The ground goes from the amp to a hole that I've drilled into the body near the rear taillight.
The problem that I have is this:
When I turn the car on, everything turns on as it should including the amp, though I get no sound from anything INCLUDING the stock speakers in the front door that have not even been rewired (They're still connected to the headunit as they have been).
If I disconnect my ground and reconnect it with the car already on, everything starts working correctly. I've tried a few different spots for the ground, all dremeled down to bare metal, and the result is the same.
I've installed quite a few car stereos before including an entirely new stereo in my Z and though I don't consider myself an expert, I'm certainly not a noob.
I'm completely stumped on this one and any help would be greatly appreciated.
