power antenna replacement | Ford Explorer Forums
dk
Virginia Beach, VA
95 XLT
Does anyone have any info or tricks of the trade on replacing a stock power antenna on a 95 XLT? Any articles or books that cover the topic? :banghead:
Refer to a Haynes or Chilton Manual.. It should be pretty easy swap. I believe its quick swap out if you go thru the inner fender liner.
I found the diagram on Autozone.com
i replaced mine about a year ago. you need to pull on whats left of the antenna. worked for me. then just feed the new one in well the motor is retackting.
