krb0212
- April 12, 2011
- Nashua, NH
- 2005 XLT
No luck yet...
Well, before you spend the money, it is a really weird problem. I thought mine was fixed and now it is all not working again. I'll briefly explain the symptoms and what the dealer and mechanics did to try to fix it.
Originally, the door ajar stays on and when vehicle is off, it thinks the driver door is open and the key in ignition alarm dings. The lock switches seemed to work if the door was closed and the key was not in the ignition. If the dome light was off, it all seemed to work okay. The rear defrost was not working and I was told that went through the security module.
Now, here is what was done. The dealer supposedly lubed all the latches. I have no idea if it was actually done and will try this again myself. My regular mechanic replaced the door sensor in the driver door, replaced the security module which is located in the side panel behind the rear passenger side seat and had it programmed, and also looked for busted wires, ground wire in particular. He may have found some.
When I got the vehicle back everything worked except for 2 things: The driver door lock can only be locked manually and the security code on the exterior key pad does not work right. For instance, when entering the code to unlock all doors, it no longer unlocks all doors. Instead, it opens the rear hatch. This was all about a month ago.
Last week, the door ajar started in again not working and the power locks no longer work unless the dome light switch is off. Also, I am not sure if all this was occurring originally, but I also recently noticed that the door ajar stays on when the passenger side door opens and closes too.(Note: this all happens if the dome light switch is in the middle position, not turned completely on and not turned off). The power lock switch does not work. The driver door lock only works manually no matter what. If I turn the dome light switch off, the power door lock switch works (except for the driver door lock), and the door ajar does not come on. Also note that when the dome light switch is on, it takes longer for the mirror lamps and dome light to time out after leaving the vehicle.
I'm going to try lubricating the latches myself to see what happens because it was reported here that it worked for several folks.
