coled43
- March 14, 2003
- Auburn, MA
- 99 XL, 02 XLS
I guess we'll say your not looking for the right things. I don't think you will find any wires hanging loose and there are no wires grounded to the steel in the door. You were looking in the right place (door panel off behind sticky paper). All the wires are bundled (taped) together and clipped to the door. They might be on the inside but you can get to them without removing more. You should be able to follow a black (w/colored marker line, a wiring diagram would say which, but you should be able to see which one) wire from each device (door latch switch, door lock switch, mirror switch) to the point where they all splice together in the door. Then that one ground wire runs from the door to the inside of the car. It is probably pinched inside the rubber hose that the wires run through between the door and pillar. If you could get the rubber grommet out of the door you might be able to get to the wire in there and repair, but I didn't want to mess with that. So, if you can unwrap the wires and get to that ground wire in the door, cut into it and connect it to another new wire and connect it to the steel of the body. Then it should work. Tape everything back up and make sure the wires are clear of moving parts. Good luck. Working through a problem like this is the best way to learn and then you will have a better idea what to look for next time.
PS
If you don't have a test light, get one. You can use it to find a live wire when connected to a known ground or test a ground when you connect it to a known live source.
PS
