Blacksheep Josh
Slinky+Escalator=Fun
- July 31, 2006
- Statesboro, GA
- '01 Ford Ranger, RIP 93 X
So basically just watch teh video. As I'm driving the battery gauge will read low, if I give it some gas it'll come back up. Here is what I've done so far:
-Battery tested, Verdict: Battery holds charge fine
-Alternator tested, Verdict: Charging correctly and putting out sufficient amps
-Power wires replaced, from Battery to Solenoid, Battery to Starter, and Solenoid to Starter
-All ground cables replaced that connect to engine/chassy
-Extra grounding cable from body to battery
-Extra wire from battery to front of under hood fuse box.
I'm at a loss. It used to only be bad during wet weather but now it's a constant problem. The only thing aftermarket installed are two 12" Kicker CVR's and a 7 in 1 L.E.D. light kit, but the problem occurs even when both systems are turned off.
Any idea will be looked at and appreciated, now for the video. It's really bad as you can see.
