Legweak87
- February 28, 2018
- 2009 Sport Trac Adrenalin
So in my 2009 Sport trac adrenalin the power door locks have decided to stop working. When using the FOB to unlock the interior lights etc. Come on but the locks don’t function and I use the key to unlock. If I press to lock, I hear the door locks working.
If I use either the drivers or passengers door unlock/lock switch, neither work.
I’ve checked the related fuse under the dash, constant power to the switch, it’s constant ground, switched ground, the wiring at the door hinge, wiring under the kick panel.
I’m going to assume it’s a relay of sorts but cannot seem to find a related relay - has anyone else had this type of problem?
