hawkeye2
- May 27, 2006
- Bellingham. WA
- 98 Eddie Bauer
1998 Eddie Bauer AWD V-8 119,000 miles.
Had the rear diff gear oil changed. Lube place used Valvoline 75w-140w fully synthetic. This matches owners manual lube spec. BUT they did not put in friction modifier as REQUIRED by owner's manual and specifically requested by me. I showed them the owner's manual lube spec pages and footnotes. They said the Valvoline bottle claimed to have all necessary limited slip additives.
Next day, On a long(600 miles), fast(75-80mph) highway trip , the rear differential started making really bad noises and had a hot oil smell. Another driver actually pulled along side to point out I had a problem. Smoke from under the car!
I had to pull off I-5 (Seattle 5 o'clock traffic) and get a tow home.
Did the LACK of friction modifier cause the overheating?
It seems the clutches would rub hard instead of sliding past.
I will open the cover today and survey damage.
PS: Lube store owner is working with me on this, but I need to verify cause of damage. So be fair with your answers. If it is my problem I will say so and get on with life. The lube store owner is willing to pay if it is the fault of their procedure.
I plan on putting in a complete low mile(50,000) axle from a totalled 97 Explorer. I found a matching D4 code axle (3.73 and Power-Lok) at the local reputable salvage yard.
Fastest fix to get me back on the road.
