power mirror switch | Ford Explorer Forums
power mirror switch
therise21
Long Island, New York
'97 XLT SOHC
i recently realized that my power mirrors dont work. either one of them. i think it is probably the switch. anyone else have this type of problem before?
Yes, my mirrors did not work when I bought my truck.(used) Turns out they weren't pluged into the switch. Pop your door panel off and look before you go buyin' anything.
My driver side one works fine, the passenger side only goes left and right, no up and down...i don't even hear the motor when i press it up and down for that side...haven't looked into it as i don't change the vertical view often. Listen to hear if the motors are working, then check the mirror switch connections (easy to do as 5.0 explained).
On my old tempo, it had power mirrors. At one point, one no longer worked. I took it apart and found that there was a "t" shaped pivot that secured the mirror to the frame, and one side had broken...allowing the "screw-like" adjusters to spin freely, while not attached to the glass, and therefore not moving the mirror.
thanks guys. there is no motor sound from either mirror, so i am hoping it is just disconnected in the door. wondering if its even worth it to fix, but i am going to because it annoys me.
