Power moon roof malfunction | Ford Explorer Forums
challanger3967
north new jersey
2006 mountaineer
The factory power moon roof opens on its own. This has only occurred while the vehicle was in drive gear, stopped at traffic light or driving, no speed preference. This has also occurred with the moon roofs open close switch removed. The only other known issue with vehicle is a TPMS issue which will be a separate post
update
Problem possible solved. A few days after the original post, I noticed a small amount of water dripping through the right map light. I cleaned the seal on the moonroof which stopped the leak. My theory is that as I park facing down a slight incline the water made it over the drip tray and into a circuit. Now that it has had time to dry everything is working normally.
clean out the dain to allow water to drain, even if you had a leaky sunroof water should not make it way in the truck, the drain is probally clogged.
