beavis195
- October 15, 2000
- Sammamish, WA and Provo, UT
- 94 XLT 4 door
How hard is this? When I idle at night with the lights on, the battery meter slowly moves to the left and the lights get dimmer. And after about 30 seconds with each bass hit (I don't have an amp, just a deck) the lights will dim. If I hit the gas though, the battery needle jumps to the middle and the lights are brighter again. We checked the battery last night, it was fine and it was replaced a year ago. I looked at the battery cables and someone has screwed with them because they are cracked where the bolt screws in and when I had to take them off, I had to use plyers on the square side of the bolt so the nut wouldn't turn the bolt, also so I could get the nut off. Plus they don't look in to great of shape. Also, could the battery cables be my problem with the power? Thanks.
