grihn
- February 24, 2011
- Leavenworth KS
- '91 XLT
Okay...so I've replaced the power steering pump twice now in my Explorer ('91 XLT, 2wd). However, it still leaks severely. After I put the second pump in, the leak seemed to stop for a bit, so I was convinced that the first replacement pump I had was just bad (they are remanufactured pumps after all). But, it's started leaking again, and before I take the pump out and go get another replacement I wanted to see if there was anything else I should check...I've also replaced both lines going between the pump and the steering box, but I've not done anything with the steering box itself. I can't visibly see any leaks with the vehicle running and someone turning the wheels lock-to-lock, and there's a significant amount of fluid on the bottom of the pump housing, so if it were squirting out of the steering box with enough pressure to get up there, I would have thought I'd seen it. Although technically I can just keep adding fluid, I really don't want to because the mess it leaves on the garage floor and driveway annoys the heck out of me. I guess another option would be to just remove the pump all together and not have power steering, though that's not really desired. I've heard all over the place that early 90's Ford power steering pumps just suck, but has anyone had this much trouble with theirs, and have you found a replacement pump that's worth a damn? The one's I've been using are from O'Reilly Auto (I think they have a 2 year warranty).
