bowtiered
- May 4, 2011
- winston-salem,nc
- 2002 ranger
I normally don't ask these questions, but it's important and i'm not to proud to admit i don't know. I was driving a 2002 ranger when i rit a rut with the front tries and it stapped the steering wheel back to center violently. immediately afterwards i lost power steering unless i revved to about 3000. I checked and saw it was pissing fluid from the power steering pump area. when i took the pump off the pressure hose seemed to be slightly loose, i was easily able to rotate the hose while the fitting remained VERY tight into the power steering pump. my question is- would this leak from the pressure hose be enough to cause a loss of power steering? or is it more likely that i blew some seals within the pump and the leak i saw was more likely coming from the pump itself? thank you very much for any input
