Power steering problem. | Ford Explorer Forums
nquizitive
Randle, Washington
00 Explorer, Eddie Bauer
Hi, I am new to the forum. I have a 2000 Explorer, Eddie Bauer, all wheel drive with the 5.0 eng.
I just finished changing the front bearing hubs. When I put the truck back on the ground and started it up the power steering was very jerky. How do I change the power steering fluid and how much fluid is required. Will changing the fluid likely cure the problem. The fluid appears dirty.
welcome
Welcome to the forum!
I have a how to in the link in my signature. Check it out.
Welcome to this forum! I've moved your thread to the stock 95-01 secton. You could disconnect the return line to drain the fluid or use a vacuum style tank to draw the fluid into it without disconnecting anything.
