power steering problems | Ford Explorer Forums
tavo123
mission texas
97 xlt
it started couple days ago at first the steering wheel would be hard to steer for a little bit while turning then it would be loose again it happend on and on today it became a little worst it got little harder and its the same thing lose and hard when turning the fluid its full ive always had it overfilled dnt know why would overfilling mess it up plz help
also i play races a lot i put electric fans couple days ago and replaced the water pump couple days ago i drive fast brake fast and sometimes turn when going fast like 35 and i floor it a lot but i believe i maintain it good nothing wrong with it got it at 215000 used have 235000 right now
sounds like you need a new rack and pinion
yeap only answer and u were right rack and pinion junk yard 70part installation 50 i might try to do it does anyone know how hard it is?
it's not that hard but time consuming.there are a few threads on the forum explaining how to do it.
if you have someone that will install it for $50 that sounds like a good deal.it took me all day to change mine.the one specialty tool that you will need is an inner tie rod removal tool.i was able to get one from advance auto as a loaner.
