Power Window Repair | Ford Explorer Forums
Power Window Repair
luccianna
Newport, VT
07 FORD SPORT TRAC LMTD
I have a 2003 Ford Explorer Sport Trac, I have to use the drivers side to open and close the windows, none of the remote buttons on any of the doors work to that window. I believe it may have something to do with the on/off of the power window switch on the main drivers side panel. Can the panel or that be replace? Does it operate with a fuse? Any idea on repairing or can someone advise me of a website where I could buy a new unit/panel for the drivers side. Thanks
power window help
tell you what i am currently dealing with the same problem right now, i talked to a friend of mine and he told me to look at the harness between the door and the kick panel ( surrounded by the rubber flex sleeve) they commonly break wires in there. i found four wires to be broken, two were for the windows, one for the door locks and one was for the courtesy light under the mirror. now this didnt fix the problem but it was a very good starting point, because i beleive if i hadnt when i found the main problem the windows still wouldnt have worked:
