Lee Iaccoca
- January 8, 2008
- Washington, DC metro-area
- 1991 Explorer EB
I have an EB Explorer '91 4dr with 200k on the clock. Its been in the family since the summer of 1990 and been using synthetics for the last 150k. The rig has good axles, an ok 4.0 engine, and Warn manual hubs were installed about 50k miles ago. So I am generally not interested in giving her up in favor of something more modern (...but with a drive train likely not much more durable).
However, all four power windows are not working. The motors in each door work (hear motor when each switch activated), but the glass won't drop or raise. I have tried greasing the guides on the side of each window with sprayable silicone with no luck. I have cracked in to the drivers side door and cleaned off/ sprayed silicone on the "metal rails" (?). Still no go, even for the drivers window.
While reading the forum here, I noticed that people were fixing their own power windows by replacing the nylon gears in each (if they had deteriorated). I might give this a go myself -- gear sets are only $15 a door.
My real question is though: How do I access the power window motor and or these gears? Do I unscrew the bolts I see on the door when I remove the trim panel, then somehow slide the motor contraption through the large holes in the door metal? Do I somehow remove the metal panel to access a doors respective power window mechanism? Its not entirely clear to me. Thanks!
