Power Windows 94 Ltd work @driver console only | Ford Explorer Forums
JamesM007
SoCal
94 Exp Limited
My 94 ltd's power windows will only work via the driver console. Every other seat's controls will not operate the windows. This, no matter what position the window lock is in. Does anyonw think this is a lock button problem or could it be something else? is it possible that the wire to the window lock has somehow become disconnected?
Thanks.
James.
If I had to guess with no testing I'd say the master window switch is inop. It's possible that it is a wiring problem.
I would start with metering the window lock switch. It sounds most likely and if there is a wire off, you will notice.
