Power Windows not working | Ford Explorer Forums
tutamen
1995 Ford Explorer Sport
I have a 1995 Ford Explorer Sport. The power windows on both the driver and passenger side are not working. I've checked the fuses and they are all OK. I've checked power to the switch while running and there is not power. BTW, the power locks do work.
I read in another post about the accessory relay being the culprit. I've changed it and still no power.
Is there any other relay or fuse that I might may not be aware of?
thank you.
Look in the left doorsill area, and in the left kick panel for a broken wire.
Also in the rubber boot between the body and the door for broken wire.
PS: Of course, you have already made sure that the window lock is not on??? Ask me how I know to check!!
thanks for the advice. it's been awhile since i made this post but other things have taken priority. I've since then checked the wiring and found no broken wires. I checked power to the switch on the light blue/white wire which i believe brings power to the switch. I also checked the same wire from within under the dash on the drivers side and also had no power. I've already replaced the accessory relay switch and that did not help at all.
Also my explorer does not have a window lock.
I also would like to add that my windshield wipers, front and rear, had stopped working at the same time the power windows stopped working.
Where can I look at next?
thank you all for any advice.
Check your owners manual for which relay(s) serve those motors. If its the same relay, remove it, clean the contacts, check the contacts on the board for burning and test or replace the relay. If its two or more relays then check the board ground, then all the circuit grounds.
I tested the relays and all tested ok. I also cleaned all of the contacts on all the relays. the power windows and the wiper still does not work. There is no power to the windows and I've checked for broken wires and have found none.
I popped off the accessory delay relay and checked for power on #85 and #86, i'm not sure which one supposed to supply the power, but neither has power. this is the pair that when energized will close the #30/#87 circuit.
If power isn't getting to the accessory delay relay, what should be my next step?
thanks
Do you have a wiring diagram? Haynes usually has pretty good ones. Check the fuse that supplies the relays, as well as continuity of the wire between. Power at the fuse? And again, check your grounds.
I used the diagrams from the following website(posted by Bobflood).
Look at this site for wiring diagrams:
http://search.ebscohost.com/
PW: rebsco
Follow prompts down to Wiring Diagrams.
All of my tests point to the GEM module. I checked fuse #26 which feeds the accessory delay relay and it has no power. Based on the diagram, the GEM module provides power to the battery saver relay which in turn provides power to fuse #26. Where is the battery saver relay? I read somewhere that it is part of the GEM module. Is this true?
The diagram says that the battery saver module is part of the GEM, pin 8. Replace the module.
Will do..thank you much for the help. I will post the result once I replace the GEM module.
I don't think the battery saver relay is part of the GEM (actually I know for sure it isn't.... :-) ).... its a relay in the relay module (of which there are up to 7 relays I think). Further, the GEM doesn't provide power to those relays mentioned... it will provide a ground. Hence, you need to check if the BSR is getting a ground and has voltage accordingly so that it will operate and switch a voltage thru to the fuse (and subsequent ADR). Replacing the GEM may or may not be the quick solution.
am dealing with the same issue with my 01 mazda b3000 and just replaced the GEM and still no windows or wipers or washer pump so any ideas are welcome also just tested all the relays in the under dash box. all seem to test fine. everything else is working and not getting any low voltage ground clicks so i am getting lost
1995 ford power windows not working ,,#12 in fuse panel 10amp
thank you.
1995 ford ranger xlt NO power windows, locks ok, mirrors ok, drivers door panel fuse box #12 fuse 10amp (book states front wiper washer system). Does also Power both windows.. I wiggiled the fuse and the relay under dash pasenger side made loud noises..(Ur relay maybe bad). Mine had BAD LOSE contacts ends in the fuse box wire tips, had to pull fuse bend metal tips one up one down away from each other , hold power window button down and just push hard to get fuse back into fuse box !! Works Solved my problem !! Randallalt@aol.com
thank you.
Door panel box Pull fuse #12 10amp 1995 ranger bend fuse tips away from each other one up one down ,, hold window button down push hard to get fuse back in slot and window should work. Randallalt@aol.com
wire broken then somewheres
Man I drove around with plexiglass over that window all winter,,,then I read this post about tapping on the motor and pushing the window button,,,,and there she goes up and down like new.
I just went through all the other suggestions and the hammer made it work just like you suggested....Thanks!
