power windows | Ford Explorer Forums
power windows
goldnblack
north carolina
1999 ford explorer
does anyone know why my power windows wont roll down on all four windows? but my doork loock buttons work? i have a 99 explorer xlt 4x4 4dr!
quick reeply would be great if possible, thanks in advance
You probably have a broken wire either at the door or down on the floor, under the floor mat. Check at the big black canister on the door. there is a bolt under the top plastic cap.
i replaced the switch and didnt work fix it, are there any fuses or relays i could check, also the black box how do i get in to that and fix it if the wire is broke?
check your owner's manual for fuses, relays and their locations. more that likely you've got a broken wire in the driver's door jam. common problem.
thanks guys for the help, and yes a broken wire is what the cause was! blue and black wire! in the door jam in the rubber boot
