LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
I am most of the way through pressing the power steering pulley back onto the pump. I am using the same tool I used to remove it.
MADDOX Pulley Remover and Installer Set ($40)
The pulley was easy to remove with this tool, as was the pulley on the original pump.
I need to press the pulley on about another 2-3mm in order for it to be flush with the front of the shaft. Looking at the pulley, it doesn't quite line up with the other parts of the S-belt system. It's close, but I am afraid that the belt will walk off if I don't have this perfectly aligned.
The pulley want on just fine up to this point, though the directions seems to be incorrect.
The directions are (my version),
1. thread the jackscrew into the puller body
2. thread the Ford 4.6L Modular screw installer into the tip of the jackscrew and tighten
3. place the bearing and thrust washer over the screw installer
4. thread the screw installer into the end of the pump shaft and tighten all the way down
At this point, you rotate the puller body down the jackscrew threads until the washer is flush up against the pulley. All of this is fine. It is the next instruction that doesn't make sense.
5. hold the jackscrew with a 1/2" socket and turn the puller body counterclockwise with an adjustable wrench until the pulley is seated.
Turning the puller body counter clockwise (left/loose) just unthreads it up the jackscrew and away from the pulley. I don't see how this could possibly press the pulley onto the shaft. I did the opposite, I held the jackscrew with a 1/2" wrench and turned the puller body clockwise to run it further down the jackscrew threads. This pressed the pulley almost all the way on. Now, this same motion just seems to unscrew the screw installer from the pulley shaft, which I don't get because I am turning everything to the right.
What can I do to get the pulley the rest of the way on the shaft (other than a 5 pound hammer)?
Am I not using the tool correctly? If this is the case I guess I would appreciate an explanation of what I am missing.
LMHmedchem
LMHmedchem
